What is the main difference between Vivado and ISE?
Vivado is new IDE launched by Xilinx, what is the main difference between it and ISE?
Teacher eilert
Re: What is the main difference between Vivado and ISE?
there's a number of points to mention.
Vivado
- handles only  Series 7 devices (S7,V7,Zync)
- supports C-synthesis (in the System Edition)
- has a new deterministic Place and Route Algorithm.
You find all this and more mentioned in the product brief and introduction videos.
Have a nice synthesis
  Eilert
Teacher eilert
Vivado
  Eilert
Thanks very much!
Agreed with eilert, also the synthesis engine are completely different.
placement are improved and hence timing.
regards,
saurav
Visitor fatihgenc84
Hi all;
What are the differences between Vivado Design Edition and Vivado System Edition ?
Check this:
http://www.xilinx.com/support/documentation/white_papers/wp416-Vivado-Design-Suite.pdf
Page 13.
To summary, Vivado Design Edition does not have HLS and System Generator.
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
