When will SystemVerilog be supported in module reference in the IP Integrator Block Design?
Hello, quick question for the forum members. I like using SystemVerilog to write my RTL code and I also like using the Block Designs. SV files are not supported in module reference within the Block Design. Are there any plans to support SV in future Vivado releases?
Thank you
Joe
Re: When will SystemVerilog be supported in module reference in the IP Integrator Block Design?
@joe306
It is in roadmap to support both System verilog and VHDL-2008 in module reference but the limitation is only when using it as a top module or entity. You can still use it by just having a Verilog wrapper around the SV file and add them to block design.
Top.v
--main.sv
https://www.xilinx.com/content/dam/xilinx/support/documentation/sw_manuals/xilinx2019_2/ug994-vivado-ip-subsystems.pdf#page=258
--Syed
@joe306
Top.v
--main.sv
--Syed
