mvanhorn
Where does Vivado in Windows put log files?
A user is running Vivado 2018.3 on 64-bit Windows 7. She is running some labs for class, and then Vivado crashes. There are no messages on the screen, but I assume that the Windows version of Vivado makes log files the way the Linux version does. But where does the Windows version save the log files?
Mike VanHorn
rshekhaw
Hi @mvanhorn ,
All the log files are created in the project directory, you can also find the current project directory by using command pwd in tcl console from vivado.
Also as you are facing crash, please check the below AR# link:
https://www.xilinx.com/support/answers/55854.html
Raj
rshekhaw
Hi @mvanhorn ,
Raj
