X Server Error, Message reported is: BadDrawable (invalid Pixmap or Window parameter)
I am getting the following error whenever I open my design in FPGA editor through command line.
I am using red hat enterprise linux server release 5.8.
I am giving the following command : fpga_editor -e my_design.ncd my_design.pcf
Any help is very much appreciated..!!
Re: X Server Error, Message reported is: BadDrawable (invalid Pixmap or Window parameter)
Is this issue fixed or not? If yes then please accept the solution.
Check your X configuration file at /etc/X11/xorg.conf and ensure that there are at least 7 X server extensions listed in the "Module" section:
Section "Module"
Load "glx"
Load "extmod"
Load "fbdevhw"
Load "dbe"
Load "record"
Load "freetype"
Load "type1"
EndSection
Check this AR: http://www.xilinx.com/support/answers/29881.htm
Section "Module"
Load "glx"
Load "extmod"
Load "fbdevhw"
Load "dbe"
Load "record"
Load "freetype"
Load "type1"
EndSection
Sorry for the late reply but issue is fixed.
