tlupick
XDMA Block Design set wrong MODE parameter on descriptor c2h bypass ports
I am using the XDMA IP in the block designer with the descriptor bypass mode set for read (H2C) and write (C2H) DMA channels.
On the module in the block design the descriptor bypass ports are added for the channels, however the H2C descriptor bypass ports are correctly set as MASTER, but the C2H bypass descriptor ports are incorrectly set to SLAVE.
This causes an issue because on my custom RTL module which controls these ports they are both (correctly) assigned to be SLAVE interfaces, but I can't connect the C2H ports because now both modules are assigned to be slaves.
Is there a way to override the interface MODE setting on the C2H bypass port on the IP?
Tim
tlupick
Vivado 2017.1
tlupick
Still not fixed in 2017.3 .
goma2
Hi tlupick,
in your VHDL source code you can define the C2H bypass interface as Master (whether it should be Master or Slave it is debatable) easily, by assigning an attribute MODE = MASTER to one of the interface signals. I discovered this by trial and error and it seems to work fine, at least at a block design level (I still have to synthesize it). For example:
attribute X_INTERFACE_MODE : string;
attribute X_INTERFACE_MODE of c2h_dsc_byp_ctl: signal is "MASTER";
attribute X_INTERFACE_INFO : string;
attribute X_INTERFACE_INFO of c2h_dsc_byp_ctl: signal is "xilinx.com:display_xdma:dsc_bypass_rtl:1.0 my_dsc_byp_c2h dsc_byp_ctl";
attribute X_INTERFACE_INFO of c2h_dsc_byp_len: signal is "xilinx.com:display_xdma:dsc_bypass_rtl:1.0 my_dsc_byp_c2h dsc_byp_len";
attribute X_INTERFACE_INFO of c2h_dsc_byp_dst_addr: signal is "xilinx.com:display_xdma:dsc_bypass_rtl:1.0 my_dsc_byp_c2h dsc_byp_dst_addr";
attribute X_INTERFACE_INFO of c2h_dsc_byp_load: signal is "xilinx.com:display_xdma:dsc_bypass_rtl:1.0 my_dsc_byp_c2h dsc_byp_load";
attribute X_INTERFACE_INFO of c2h_dsc_byp_ready: signal is "xilinx.com:display_xdma:dsc_bypass_rtl:1.0 my_dsc_byp_c2h dsc_byp_ready";
attribute X_INTERFACE_INFO of c2h_dsc_byp_src_addr: signal is "xilinx.com:display_xdma:dsc_bypass_rtl:1.0 my_dsc_byp_c2h dsc_byp_src_addr";
LR
christian.lambricht
In Vivado 2017.4 that seems to work well.
Tested in Verilog and VHDL.
ATTRIBUTE X_INTERFACE_MODE of cfg_pm_aspm_l1_entry_reject: SIGNAL IS "MASTER";
But in Vivado 2018.1 X_INTERFACE_MODE seems not working for verilog!
(* X_INTERFACE_MODE = "XIL_INTERFACENAME pcie4_cfg_pm, MASTER" *)
(* X_INTERFACE_INFO = "xilinx.com:display_pcie4:pcie4_cfg_pm:1.0 pcie4_cfg_pm pm_aspm_l1entry_reject" *)
output  wire                cfg_pm_aspm_l1_entry_reject;
(* X_INTERFACE_INFO = "xilinx.com:display_pcie4:pcie4_cfg_pm:1.0 pcie4_cfg_pm pm_aspm_tx_l0s_entry_disable" *)
output  wire                cfg_pm_aspm_tx_l0s_entry_disable;
Any body has an idea?
Best regards,
Christian
christian.lambricht
OK It seems that the correct way in verilog is
(* X_INTERFACE_MODE = "MASTER" *)
