Observer richterfhg
XTCLSH: build from generated tcl script fails if IP cores in project
When I try to build a project including IP cores (in my case FIFOs) with the automatic generated TCL script, the build fails due to wrong top module. All files are added and compiled, but the XST is called with the wrong .xst and input/output files. The "project set top" is correct in the script, but xst is called only with one of the FIFO .xst/-ifn/-ofn.
Projects without IP cores are built correctly using "xtclsh project.tcl rebuild_project" Where is the problem? How can I build such projects from the tcl shell using the ISE generated script?
Edit: I´m using ISE 13.2 with Windows 7 x64
Re: XTCLSH: build from generated tcl script fails if IP cores in project
Thanks for reporting this.
It is kind of weird but the problem seems to be due to the following default project setting being reset.
   project set "Working Directory" "."
If you comment out this line, it should work for projects with IP cores included.
Observer richterfhg
OK, thanks for the answer. I will try this at the next project. For now, teamcity controls the design flow via the command line invoking of the xilinx tools. This works also.
