Xilinx Design Language
hi
      does anybody knows the Xilinx Design Language(XDL) generated by ISE13.4?if so,please help me.
     thanks in advance!
     handoujack!
Re: Xilinx Design Language
If you are interested to read a XDL file after converting from NCD refer
http://www.fpgadeveloper.com/2011/06/how-to-read-an-ncd-file.html
If you would want to use Xilinx Design Language tutorial, refer
http://www.mn.uio.no/ifi/english/research/projects/cosrecos/publications/paper/recosoc11beckhoff.pdf
http://www.ee.unlv.edu/~selvaraj/ecg707/lecture/Xilinx%20Design%20Language.pdf
--Hem
If you mean design entry language, Xilinx do not have separate language XDL on its own, it follows industry standard HDL (hardware description Languaage)
You can generate a design in either VHDL or Verilog, you can select the language in project options as shown below
Hope this helps.
Vanitha
--Hem
hi
      Hem, do you  know how to generate the .XDL file like the http://www.ee.unlv.edu/~selvaraj/ecg707/lecture/Xilinx%20Design%20Language.pdf used.
thanks!
handoujack.
Ofcourse, type the command xdl in the command line suite as shown here.
--Hem
Scholar brimdavis
@handoujack : "does anybody knows the Xilinx Design Language(XDL)"
Xilinx's original XDL documentation can be found in certain older versions of ISE/Webpack.
Download and install a copy of ISE WebPACK 6.3i from here:
http://www.xilinx.com/webpack/classics/wpclassic/
Then take a look at the files in %XILINX%\help\data\xdl
-Brian
I use the command (ISE6.3):xdl –ncd2xdl test.ncd test.xdl, and the xdl file is different from the “The Xilinx Design Language (XDL):Tutorial and Use Cases” described.
Why is my xdl file different from the file mentioned in “The Xilinx Design Language (XDL):Tutorial and Use Cases”?
Thanks!
Handoujack.
Visitor pospij5
Hi, what is the difference? Do you use the same part as they use in the tutorial? Some naming conventions seem to be different for different parts...
@brimdavis: thanks for the link to old versions - finally I have also an "official" documentation;)
Visitor sb_cse
Does anybody know how to generate Xilinx Design Language file for a FPGA interconnect resources using C or C++ language?
Scholar markcurry
The XDL file format has no relevance to today's FPGA designs.  Why do you think you need it?
The format was barely needed in some weird design flows in the ISE days.  (I don't think I ever used it outside of some PlanAhead tutorials).  I don't think the file format is used in Vivado at all.
Can you give us ideas on what you're trying to accomplish?
Mark
Visitor sb_cse
Hi, I am trying to generate routing path which is a collection of subsequent PIPs and Wire segments (Interconnection resource) based on some algorithm. I want to write C code for this path generation problem which will give the output in XDL format.
Visitor sb_cse
can anybody please tell how many single, double, long, pent , hex lines are there in virtex 6 and virtex 7?
