Xilinx Document Navigator - Error creating SSL context"
I have problems starting the Document Navigator on my system running Ubuntu 18.04.2 LTS (x86_64). The tool does not update the catalog with the attached error message.
I already tried
https://www.xilinx.com/support/answers/66184.html
https://forums.xilinx.com/t5/General-Technical-Discussion/2016-3-Documentation-Navigator-ERROR/td-p/728494
https://github.com/wkhtmltopdf/wkhtmltopdf/issues/3001
with no luck :-(
Thanks for your support!
derkai
I had the same problem and was unable to find a fix. In order to install DocNav 2018.3 again, I had to first uninstall DocNav 2019.1 by doing the following:
/<Xilinx install directory>/.xinstall/DocNav/xsetup -Uninstall
Then I re-ran the 2018.3 webinstaller to install DocNav.
Mentor
Mentor
Hi @derkai
  I have the same issue on Fedora 30 (not officially supported) with DocNav 2019.1, though it worked fine with all 2018.x versions.
-Pat
https://tuxengineering.com/blog
Same problem here on Pop!_OS 18.04, though the documentation navigator still seems to function normally.
I've found a work around of DocNav 2019.1 on Ubuntu 19.10
install qt4 libraries using apt, then move all qt libraries under docnav dir to a backup dir, that will force docnav to use system qt libs, it seems work.
inspired by this issue: https://forums.xilinx.com/t5/Installation-and-Licensing/docnav-fails-to-start-when-Qt-libs-are-installed-libQtDBus/td-p/763521
