Xilinx ISE Text Size in RHEL6
I'm have a bit of trouble reading the text in the ISE tool set due to the font size in RHEL6
A previous posting suggested using qtconfig in RHEL5.
While changing the font size in qtconfig appears to only change the font size in the qtconfig tool itself, it makes no visible change to ISE.
How can I make it readable?
Steve
Check this answer record: http://www.xilinx.com/support/answers/16876.html
Vinay
Hi Vinay,
Thanks for the reply.
That didn't appear to do anything either.
Steve
You did not mention ISE version. If it was one of latest ISE versions,
try setting environment variables  XIL_GUI_APPFONTNAME and XIL_GUI_APP_FONTSIZE
and see if it helps.
Krishnan
