edecont
.Xilinx folder in $HOME - Change location
I see a folder .Xilinx created in the unix $HOME and attempts to write to it during Vivado compilation. Can we change put this folder somewhere else? My company nightly regression user has a $HOME that cannot be written to.
-Eduardo
edecont
We manage to work-around it by creating empty directories in .Xilinx. Only directory existence seems be required in our case.
ll Common/2020.1/
total 0
ll Vivado/2020.1/*
Vivado/2020.1/commands:
total 0
Vivado/2020.1/reportstrategies:
total 0
Vivado/2020.1/strategies:
total 0
whitehorsesoft
Firstly, this seems to me like an environment setup issue, not a Vivado issue. It is quite strange to have a setup that allows no write access to a user's $HOME location, for that user.
Secondly, for clarification, $HOME was not specifically specified during during the installation process, and also the current project isn't being saved to a folder within $HOME, correct?
Lastly, have you tried (or asked your sys admin to try) pointing $HOME to a location that does have write access?
edecont
ll Common/2020.1/
total 0
ll Vivado/2020.1/*
total 0
total 0
total 0
whitehorsesoft
Very good. Please feel free to mark answer as an accepted solution if it addresses your issue.
