ZCU-104 using reVISION zcu104-rv-ss-2018-2 for See3CAM_CU30_CHL_TC_BX
Hi all,
I downloaded zcu104-rv-ss-2018-2 from reVISION github. I would like to know the IP Block Diagram used in the optical flow application. However, I only manage to find a .dsa file in the Hardware folder.
May I know how to open a .dsa file and extract the PS-PL configuration and edit in Vivado IDE.
Thank you
Tags (3)
HI @ang083 ,
You should be able to use the command open_dsa in the vivado TCL console to open the DSA.
The dsa file can open in Vivado console use open_dsa command.
But reVISION hardware need some IP license. HDMI, MIPI ...
I also fail synthsis in Vivado.
