Zynq 7010: The physical port 'S_AXI_GP3_wr_socket' specified in the portmap, is not found on the block!
Anytime I place a ZYNQ7 Proccessing System IP Block into a block design I am met with the following warnings:
WARNING: [BD 41-176] The physical port 'S_AXI_GP2_rd_socket' specified in the portmap, is not found on the block!
WARNING: [BD 41-176] The physical port 'S_AXI_GP2_wr_socket' specified in the portmap, is not found on the block!
WARNING: [BD 41-176] The physical port 'S_AXI_GP3_rd_socket' specified in the portmap, is not found on the block!
WARNING: [BD 41-176] The physical port 'S_AXI_GP3_wr_socket' specified in the portmap, is not found on the block!
Is this a cause for concern? Do I need to update my IP catalog somehow? I am using Vivado 2019.2
Hi sam.lcompton@gmail.com ,
Can you reset output products and regenerate them and see if it resolves this issue?
It is recommended to reset output products if you modify anything in your block design. We have seen some issues in which reset output products helps to resolve the issues.
Thanks & Regards
Anil B
Hello all,
I am experiencing the same issue.
Setup:
  • Ubuntu 18.04.5 LTS
  • Vivado 2020.1
  • Zedboard
I am creating a RTL project for Zerdboard, without any HDL source but with one constraint file.
Then I create the block design and when I instantiate the Zynq7_Processing_System IPCore, then Vivado instantiates it but it generates also the following WARNING messages:
# create_bd_cell -type ip -vlnv xilinx.com:ip:processing_system7:5.5 processing_system7_0
With Vivado 2019.1 that is not happening (no warnings related to the PS7 instantiation)
Could you please explain why?
Thank you,
Best regards
@andrea.foradori
I was able to reproduce the issue and reported it to the factory. The warning is not reported in 2019.1 but present in 2020.1.
I will get back to you once I get an update.
--Syed
Hello,  are there any updates on this?  Has it been resolved?  can it be ignored?  Thank you.
@dianafl1
After block design connections clear the message in the message window by click on Recycle button as shown below. This will clear the warning messages.
Validate the block design and check if the same warning is still reported.
--Syed
