Zynq UltraScale+ MPSoC IP export I/O
The Zynq-7000 IP wizard has the option to export its MIO-configuration to a spreadsheet format. Is it possible to do the same for the I/O-configuration of a Zynq UltraScale+ MPSoC IP?
Hi @larshb ,
Follow the below steps:
1. Open block design.
2. Double click on zynq processing system.
3. In MIO configuration tab, right click on any of the IO peripheral and select export to spreadsheet.
4. Select the the location for XLS file to created and click on OK.
Now check the generated XLS file.
Raj
I already tried that, but apparently the Ultrascale processing system wizard does not work the same way.
