add source error in ISE 12
Whenever I try to add a *.v source file into an ISE project, there is an error:
*.v is already in the project it cannot be added again. If the file does not appear as expected in the design hierarchy, you may need to change the view association in the Files panel.
But in the Files panel it states: View Association = All.
What is wrong with it?
Senmeis
As error states, you had already added the *.v file to the project. To confirm this, click on "Files" tab in the left pane of project navigator window.
If the file is present and not shownup in the hierarchy, check the instantiation in the top module.
Professor
Professor
Normally if you add a verilog file to your project and associate it to "all" or "synthesis" it will
show up in the hierarchy pane whether or not it has been instantiated into the top level.
However if there is a serious syntax error, it won't show up if the parser cannot make out
that it actually contains a module definition.  This could happen if you forgot a `endif
to a `ifdef for example.  Unfortunately, when the file is not in the design hierarchy it becomes
hard to run a syntax check on it...
-- Gabor
-- Gabor
