Scholar muravin
adding a UTC timestamp into the canvas or RTL
Hi All,
I want to add a results of TCL command 'clock seconds' into a register in one of the IPs.
Ideally we did this through some .vh file however, when the output products are generated, the IP is copied into /ipshared/ folder and as such, the path to that .vh file is no longer valid. I also tried adding it to the main project and this is not good either.
I can think of a way to just connect the interface port to this value through xlconstant, i.e. see below
startgroup
create_bd_cell -type ip -vlnv xilinx.com:ip:xlconstant:1.1 xlconstant_0
endgroup
Then I can perhaps do something like this:
startgroup
set_property -dict [list CONFIG.CONST_WIDTH {32} CONFIG.CONST_VAL {[clock seconds]}] [get_bd_cells xlconstant_0]
endgroup
Would this work? Is there a better way to get this?
Vlad
Vladislav Muravin
Scholar muravin
Re: adding a UTC timestamp into the canvas or RTL
Ah... Thanks Randy, it worked.
Cheers Vlad
Vivado% create_timestamp
Wrote  : </home/IGNIS/vmuravin/projects/orchestra/vivado/eclipse/eclipse1/eclipse1/eclipse1.srcs/sources_1/bd/system/system.bd>
Vivado%
Vladislav Muravin
Scholar muravin
Hi Xilinx,
This does not work! I added the following proc to our main project management TCL file, and I get an error, see it after the proc. If I use set t [clock seconds] and replace it with $t, I get the same error.
How can we pass string in a form of a variable to the main BD??? I thought this is a TCLized business A-Z.
Thanks Vlad
proc create_timestamp {args} {
    set mainprj::utc [clock seconds]
    open_bd_design [current_project]/[current_project].srcs/sources_1/bd/system/system.bd
    set_property -dict [list CONFIG.CONST_VAL {[clock seconds]}] [get_bd_cells xlconstant_timestamp]
    save_bd_design
    close_bd_design [get_bd_designs system]
ERROR: [IP_Flow 19-3452] Invalid long/float value '[clock seconds]' specified for parameter 'Const Val(CONST_VAL)' for BD Cell '/xlconstant_timestamp'.
INFO: [IP_Flow 19-3438] Customization errors found on '/xlconstant_timestamp'. Restoring to previous valid configuration.
ERROR: [BD 41-245] set_property error - Invalid long/float value '[clock seconds]' specified for parameter 'Const Val(CONST_VAL)' for BD Cell '/xlconstant_timestamp'.
Vladislav Muravin
Try the following:
set_property -dict [list CONFIG.CONST_VAL [clock seconds]] [get_bd_cells xlconstant_timestamp]
I think the {} prevents the evaluation of [clock seconds]
Randy
Scholar muravin
Cheers Vlad
Vivado%
Vladislav Muravin
