Voyager
Voyager
auto concatenate io port
is there an auto concatenate or easy way to concatenate bunch std_logic/single bit signal into a large bus in VHDL or verilog?
Re: auto concatenate io port
Hi @s002wjhw ,
I guess what you are looking for is configuring IO ports, if yes please check page no.36 of below link:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug899-vivado-io-clock-planning.pdf
Raj Singh.
Hi @s002wjhw
please see the concat IP present on the page 29 of the following document.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug994-vivado-ip-subsystems.pdf#page=29
Suraj C
Scholar dpaul24
@s002wjhw,
In VHDL the simplest way would be to declare an array and use it. The array would constitute your 'bunch of signals'. For individual use you have each signal represented as bunch_signal(#).
FPGA enthusiast!
All PMs will be ignored
Scholar drjohnsmith
regarding using an array as ports,
  be aware, that till recently, VHDL, an array had to be all, input, output , or bi  ,
     There are other optoins, like dleayed enumeration, generics ,
  let us know a bot more as to what you want to do .
