Voyager
Voyager
axi quad spi v3.2(vivado 2015.4) slave select pin doesn't assert
My setup for axi quad spi on zynq is the following figure.
The value of SPI control register is 0x86.
The firmware transmits some value  in infinite loop.
When I checked ss[0], sck, io0 with oscilloscope, the signal sck, io0 looks normal.
But ss[0] is always high. It never assert to active low.
"manual ss mode" means you need to manually toggle ss ie it's your responsibility to set it low before you start the transaction.
are you using auto ss mode or manual ss mode?
Voyager
Voyager
Thanks for your replay
I used manual ss mode.
This is my firmware program.
spi[SRR] = 0x0000000A; // Reset
set_bit(&spi[SPICR], MTI, 0); // Master Transaction Inhibit disabled
set_bit(&spi[SPICR], MASTER, 1); // Master configuration
set_bit(&spi[SPICR], SPE, 1); // SPI system enabled
// SPICR(SPI Control Register) Manual Slave Select Assertion Enable : 1(default)
// SPISSR(SPI Slave Select Register) : 0x1 (default)
uint8_t dat[5] = {0x02, 0x07, 0x38, 0x40, 0x00};
while (1) {
   for (int i=0; i<5; i++) {
        spi[SPIDTR] = dat[i];
        while ((spi[SPISR]>>TX_FULL)&1);
   usleep(100);
cyan color is ss, yellow is sck.
Is there something wrong in my firmware?
Voyager
Voyager
I fixed my firmware to toggle the 0th bit of SPISSR.
Now, it works well
Thank you again
Hi hokim,
May i know the firmware for toggling the SPI slave select register.Kindly share the firmware or an idea.
Hi In this picture the sclk in not a square wave. I meet this problem in my design too. Did this signal look normal after you fixed your firmware?
Hi, I understand that we must set the cs to low before a transaction, but in the example provided by xilinx they don't set the cs to high once the tx is finished, do you know why?
path: (folder were you install vivado)
data\embeddedsw\XilinxProcessorIPLib\drivers\spi_v4_4\examples\xspi_eeprom_example.c
they select the slave but never deselect it
	 * Set the SPI device as a master and in manual slave select mode such
	 * that the slave select signal does not toggle for every byte of a
	 * transfer, this must be done before the slave select is set
	Status = XSpi_SetOptions(&Spi, XSP_MASTER_OPTION |
					XSP_MANUAL_SSELECT_OPTION);
	if (Status != XST_SUCCESS) {
		return XST_FAILURE;
	 * Select the slave on the SPI bus, the EEPROM device so that it can be
	 * read and written using the SPI bus
	Status = XSpi_SetSlaveSelect(&Spi, SEEPROM_SPI_SELECT);
		return XST_FAILURE;
thanks
