linzhongduo
bd.tcl to generate HDL parameter in Custom IP
I am trying to design an IP that will infer the bus data width and propagate the width to a parameter in HDL called "C_DATA_WIDTH". The question is similar to the following question, except that I couldn't get it working. So I am trying to figure out what I did wrong.
http://forums.xilinx.com/t5/Design-Entry/How-to-I-get-the-Auto-button-in-custom-IP/m-p/554352/highlight/true#M7382
There are several points I would like to clarify:
1) the parameter C_DATA_WIDTH is set to be of value resolve type "user", should I make it generated or others?
2) My bd.tcl is as follows. In the propagate proc, I puts a line to make sure it is called, but it is never executed.
proc init {cellpath otherinfo} {
set cell [get_bd_cells $cellpath]
bd::mark_propagate_overrideable $cell {C_DATA_WIDTH }
proc propagate {cellpath undefined_params} {
puts "propagate is called"
set ip [get_bd_cells $cellpath]
set busif [get_bd_intf_pins $cellpath/ch0]
set busParent [find_bd_objs -relation connected_to $busif]
set_property config.C_DATA_WIDTH [get_property config.MEM_WIDTH $busParent] $ip
3) I have attached the file group in the IP packager, is the naming and file group setting correct?
Jimmy
Screenshot from 2015-03-11 10:49:56.png
vemulad
Have you referred to below documents
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_3/ug1119-vivado-creating-packaging-ip-tutorial.pdf
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug1118-vivado-creating-packaging-custom-ip.pdf
Deepika.
Deepika.
linzhongduo
Hi Deepika,
Thank you for your quick reply. I did go through them, but couldn't find any information about the tcl script. I couldn't find any Xilinx documentation actually talks about what "proc propagate" mean except the answer record listed in my question. Could you please give me some pointers?
Jimmy
vemulad
Hi Jimmy,
Have you referred to "customization parameters" page-33 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug1118-vivado-creating-packaging-custom-ip.pdf
Deepika.
Deepika.
linzhongduo
Hi Deepika,
Thank you for the response. I am not sure if I understand what you are trying to say with page 33. It was about visibility, are you saying that if I want to make it configurable through bd.tcl, I should make it hidden? I think a lot of Xilinx IPs with AXI interface have ID_WIDTH auto configured, but the parameter is still visible though not editable.
Jimmy
linzhongduo
Hi Deepika,
I tried to set visibility, but doens't seems to be right. Another question: if I set the parameter C_DATA_WIDTH using tcl command in the GUI, I can see that the property is changed, however the interface width which depends on the parameter doesn't change at all. So it seems that I need to somehow invoke the tcl script to set the GUI as well.
Is there a simple example showing how to use the bd.tcl for inferring IP parameters? Thank you.
Jimmy
shruti08
Hi Jimmy,
Were you able to resolve this? I am trying to set a generic in my custom IP based on the value entered in the BD using the bd.tcl for the IP. As you have mentioned, I don't even see the propagate procedure being executed.
Any help would be appreciated.
-Shruti
wermke
Same question ...
Reto
Hi @wermke
Hi @shruti08
Hi @linzhongduo
Hi @vemulad
Has anyone of you solved this problem?
Thank you
Kind regards
Reto Meier
