nibal
blk_mem_gen_8.3 bd.tcl bug in Vivado 2015.4
Although said component sports AXIS interfaces, they are not supported in its bd.tcl, with the result of this error:
ERROR: [BD 41-1273] Error running post_config_ip TCL procedure: ERROR: [Common 17-55] 'set_property' expects at least one object.
::xilinx.com_ip_blk_mem_gen_8.3::post_config_ip Line 14
and open_bd_design failing due to it, unless PORTA & PORTB are defined.
Plz fix, and do smt about these error messages. They are confusing and missleading.
vemulad
Hi @nibal
Are you manually creating the bd tcl? Can you attach the TCL file here?
Deepika.
nibal
Hi @Deepika,
Ty for your fast reply.
No. This is Xilinx software, and I am referring to the stock bd.tcl for blk_mem_gen_8.3 from vivado 2015.4 (/opt/Xilinx/Vivado/2015.4/data/ip/xilinx/blk_mem_gen_v8_3/bd/bd.tcl).
I would be very curious if your stock bd.tcl differs from mine. Regardless, I'm attaching it, and plz let me know if you see any differences...
pd.kermani
I've got the same error while re-customizing Aurora64b66b at 8.0gbps in Vivado 2016.2 on Kintex-Ultrascale with following error:
set_property -dict [list CONFIG.C_LINE_RATE {8.0} CONFIG.C_REFCLK_FREQUENCY {800}] [get_bd_cells aurora_64b66b_0]
Resolution: If [get_<value>] was used to populate the object, check to make sure this command returns at least one valid object.
    ::xilinx.com_ip_aurora_64b66b_11.1::post_config_ip Line 806
INFO: [Common 17-17] undo 'set_property -dict [list CONFIG.C_LINE_RATE {8.0} CONFIG.C_REFCLK_FREQUENCY {800}] [get_bd_cells aurora_64b66b_0]'
ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
endgroup
Moreover, there is no problem if I set other Lane rate like 4.0, 6.0 or 12.5.
