block design script - question about 'excluding' message in log
Accepted Solution Solved
Accepted Solution
I used 'write_bd_tcl' to save a tcl script that recreates my block diagram
when I run the tcl script, I can see the following in the vivado.log file right before the bd is save :
Excluding </snap/axi_dma_0/S_AXI_LITE/Reg> from </snap/axi_dma_0/Data_MM2S>
Excluding </snap/axi_gpio_0/S_AXI/Reg> from </snap/axi_dma_0/Data_MM2S>
Wrote  : </home/zynqdev/Zynq/2015_4/zynqsnap_test2/zynqsnap_test/zynqsnap_test/zynqsnap_test.srcs/sources_1/bd/design_1/design_1.bd>
Now I'm wondering what these 2 lines 'excluding' mean ...?
** kudo if the answer was helpfull. Accept as solution if your question is answered **
Re: block design script - question about 'excluding' message in log
Hi @ronnywebers,
See Exclude segment from UG994:
Basically this is when you have an interconnect with multiple master. Some master do not need to access some slave so the slaves are excluded from the mapping of this particular master
-> I don't know if what I am writing is clear... let me know if not.
Hope that helps,
All Replies
Hi @ronnywebers,
Hope that helps,
ok - so I see this is because I have DMA controllers in my design :
for snap/axi_dma_0 there are 2 exclude segments, these match with the 2 lines in the Vivado.log file. I think block automation has created this for me, 'cause I don't remember adding this manually.
it's strange though that snap/axi_dma_1 does not have these exclude segments, probably that the block automation missed these? And also, besides the axi_gpio_0 and axi_dma_0 there are some other AXI IP's that could probably be excluded.
I understand from UG884 that this is optional / a choice in my design, to prohibit that the DMA accidentally accesses other AXI IP, as it only needs to stream fifo data to DDR3 memory, and nothing else (?)
Hi @ronnywebers,
> Do you have this in your original BD? It was maybe done when auto-assigning addresses
> Yes this is a bit strange. I cannot find a reason
> I guess yes... (I have never used it...)
