block design wrapper in systemVerilog
Is it possible to generate block design wrapper in systemVerilog?
and more specipic - it is possible to make the AXI ports (in or out) as a systemVerilog interface Type for ports of a module?
Tx
Yotam
Hi @yotam
No, not at this time.
When you click on create wrapper it checks what language the project is set to and creates the wrapper based on that.
At this time there are only VHDL or Verilog as options.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
thanks
Is system verilog on the Vivado rodemap?
Yoti
Hi @yotam ,
There are various features of system verilog which are in roadmap but not sure which one are they. But as per latest Vivado 2019.1 user guide(UG1118) it is recommended to use a Verilog wrapper around a System Verilog file:
Page no. 11 :
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1118-vivado-creating-packaging-custom-ip.pdf
And we recommend to follow the user guide.
Raj Singh.
