amritkumar2306
can IP created by me, be implemented in a FPGA board
I have written a verilog code for a digital modulator and sram. I have used readmemh to load some external data into the SRAM. Now i want to feed the data stored in the SRAM to the modulator. Can i do this by creating new IPs for the RAM and Modulator and connecting them through block diagram?? If yes afterwards can i implement the entire block in zc706 FPGA.
kdeshwal
Hi @amritkumar2306 ,
Yes, you can create and package a custom IP.
Please check UG1118 (Creating and Packaging Custom IP User Guide)
Kuldeep
Please give Kudo and Accept as a Solution if solution provided seems helpful.
Have a look at our Versal Design Process Hub, Versal Blogs and the Versal Forum Useful Resources
kdeshwal
Kuldeep
