cannot make VHDL instantiation of clock wizard
Dear all
Here in Xilinx forum   (https://forums.xilinx.com/t5/Design-Entry/clock-wizard-v5-1-deliver-verilog-only/td-p/670664)  i have find out that Vivado 2015.4 Clock Wizard IP 5.2 can do VHDL instantiate.
I attached print screen, please answer me, what i forget to do, and why I cannot make instantiate PLL to my project ?
Hi @gabirmann
Please close the thread my marking the appropriate post which helped you with the resolution as "Accepted solution". This will help the future users.
Rohit
Rohit
please go to the "IP sources" tab. There you can instantiation template of your desired language. VHDL or Verilog.
Thank you
Rappy
Hi @rappysaha,
Post you code this way we can see what is missing.
OMG, that's work ! Thank you !
Hi @gabirmann
Rohit
Rohit
