clone a project in vivado.
there are a few similar results on this in the forums but I've had no joy.
I've also used the TCL archive_project, etc with no luck. It's not what want.
Please forgive me if I my searching has not worked
What I want to do :I have a project, and all the sources , everything is down from one directory. It's not scattered...
Then I wish to  go and modify the clone as a separate entity.
Simple right ?
Well, just copying the directory and opening the (copied) project reveals all sorts of uglyness that I spend a couple of hours fixing, and a mess is made ... There appear to be fixed directory (not relative) dependencies....
I end up with a bunch of my source files (I keep in their own directory) imported into the project if I try to . get vivado to sort it out . In my project I never have vivado 'copy sources into project' , always just add sources (references) .  Is this way I do things fighting me ?
What am I missing here .....
Any suggestions will save me much time and teeth knashing with this otherwise fine (Vivado) product.
with thanks
glen english.
Guide avrumw
Guide
Re: clone a project in vivado.
With the project open in the GUI you can just do "Save Project As..." and select a new directory - this will copy all the files related to the project to a new project under the new directory.
The same thing can be done by script using the "save_project_as" command.
Avrum
@glenenglish,
If your query is addressed, please close this thread by marking appropriate reply as solution.
Nupur
Hi Avrum
I just got the notification of the your reply.
I tried that under 2015.4 and was left with missing parts of the project- mainly the Xilinx IP appears to be missing great slabs of configuration, too many error messages to list. I will try under 2016.2 and see how I go.
With thanks
