rs2015
copy part or all of a block diagram?
is there a way to copy part or all of a block diagram from one Vivado project to another project?
I tried copy, but when I go to the other project, the paste doesn't work.
An export/import method?
aher
Hi @rs2015,
Glad to know.
If that answers your query, please close this thread by marking answer "Accept as Solution"
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
aher
Use write_bd_tcl
this will generate script of your current IPI BD. Source this script to your new design.
More information UG835
-Shreyas
rs2015
Thanks I did this.
When I sourced in the destination project, it created a second totally separate block design in the project.
Then I did a select-all and copy, and I was able to paste the whole thing into the main block design.
Then I deleted the extra block design.
So it worked. Thanks!
aher
Hi @rs2015,
Glad to know.
-Shreyas
fkhalili
Hi!
Thank you, it is really a useful method.
Farnam
