Visitor halils
copying design sources
I have two different projects and I want to copy one of the modules and its submodules, generated ip's,coe files from one project to another. I dont want to use add files, because both projects has different modules with same name. Is there a way to select one module and everything under it from the hierarchy and copy it to another project? I'm doing this by hand however, I wonder is there a better way.
Re: copying design sources
@halils
Use "save as"  option which will create a new copy of your entire project. From Vivado, Select File-->Project-->Save as..
Now delete the unrequired modules.
The equivalent TCL command is:
save_project_as project_new C:/My_projects/project_new -force
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug835-vivado-tcl-commands.pdf#page=1526
--Syed
--Syed
@halils
--Syed
--Syed
@syedz
I have often wanted the “save as” feature for Xilinx IP.  That is, from within a Vivado project:
- open previously configured IP
- change IP configuration a little
- save IP with a new name
markg@prosensing.com
Once you change the IP configuration and click OK then the existing IP gets overwritten with new change and changes will refelect in IP files. Currently the GUI doesnt allow you to change the IP name or its location from the existing IP. I will forward your feedback to Factory.
--Syed
