could not find "upgrade_log file"
Hi all
I got an error mesage with
[Project 1-19] Could not find the file 'D:/uB_custom_IP/5simpleIP_createPORT/project_1/project_1.srcs/sources_1/bd/design_1/ip/design_1_simple_port_0_0/design_1_simple_port_0_0.upgrade_log'.
There is no problem when I checked my custom IP location at "project setting"
Do you know why it is happened?
I appreciate for any comment or help.
Thank you
Re: could not find "upgrade_log file"
Hi @tw011
Did that helped soving your issue?
Thanks,Vijay
Are you using Vivado 2013.4? We have seen such issues with 2013.4 and resolved the same in 2014.1
Check this AR for more information.
http://www.xilinx.com/support/answers/57653.html
Thanks,Vijay
Thank you for reply
I have seen this post before
I forgot to mention about the version of VIVADO
VIVADO 2015.2 has been used for this question
Thank you
Hi @tw011
Do you deleted the IP files from the disk?
I mean to say .right click on the IP and select remove file from project & in the pop up dialog check the box to delete file from disk?
Try creating the project from scratch and see if that helps.
Thanks,Vijay
Thank you for comment @vijayak
I didn't erase any IP.
I will generate ouptut again
Thank you
Hi @tw011
Thanks,Vijay
sorry for late response
thanks for help. it works
But, I want to know any other way to fix it, because I think erasing IP & making it again is not efficient way.
Anyway Thank you
