mkarwat
custom IP Packer parameter range as expression
Hi, I want to set parameter range in custom IP similar to what is described on page 54 in this document:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1118-vivado-creating-packaging-custom-ip.pdf
But I want to use an expression instead of a constant value, for example Maximum = pow(2, $data_width ) -1.
I can set the exact value using an expression with Editable = No, Dependency = Yes, But id doesn't work for range. Is it possible?
