custom IP and IP integrator in non project mode
Hi all,
As my understanding , we can use an IP integrator(block design) in non project mode by sourcing the TCL file.
(after creating block design in project mode and wtite_bd_tcl to save block design to a TCL file).
Is it possible to use a custom packaged IP in the IP integrator and use it in non-project mode?.
Means, I have packaged a directory containing two files a.v and b.v to component.xml. I can use this in the IP integrator in project mode. Can I use this in IP integrator in non-project mode? If possible, what are the steps and commands?
I use Vivado 2017.1
Anoop
Re: custom IP and IP integrator in non project mode
@anoopjoseph,
Yes, it is possible. To know the exact steps complete the flow in GUI and check the TCL commands in TCL console.
Note: for custom IP, You will need to add the IP reprository and refresh the IP catalog.
set_property  ip_repo_paths <repo_path_list> [current_fileset]
update_ip_catalog
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug912-vivado-properties.pdf#page=237
--Syed
Newbie soccerchamp
@syedz,
Thanks for your reply.
I just changed my user ID.
Your solution seems working. But I have some other problem. Could you please help?. I gave below commands.
update_ip_catalog
source design_bd.tcl
generate_target all [get_files design.srcs/sources_1/bd/design_bd/design_bd.bd]
synth_design -top ${design_name} -part ${device}
When RTL elaboration start, following error occurred. Did I miss anything?
ERROR: [Synth 8-439] module 'design_bd_axi_apb_bridge_0_0' not found [design.srcs/sources_1/bd/design_bd/hdl/design_bd.v:388]
Anoop
Observer soccerchamp
I found a solution.
After generate_target all, .xci corresponding to each IP in IP integrator will be generated in sources_1/bd/design_bd/ip/design_bd_*/
They need to be synthesized as OOC modules.
So I read each .xci files and synthesized them in a loop using synth_ip command.
After I did this, I could able to synthesis my TOP module.
Thanks & Regards
An
