custom ip packaging: integrating user design example (2017.4)
We've created a custom IP (AXI based). It works well as we've been testing it on a ZCU102 board.
Therefore, we've implemented a custom example design using that IP.
Is it possible to integrate this exemple in a new release of the custom IP?
Ideally, we could have access to "create exemple desing" in the context menu related of the IP in the IP integrator.
Is that possible?
thanks.
Sébastien
--Sebastien
Re: custom ip packaging: integrating user design example (2017.4)
UG1118 also gives an input on that subject.
Add file group, select example design and script.
It solves my request.
--Sebastien
Voyager
Voyager
Take a look at lab 2 of UG939.
Adaptable Processing coming to an IP address near you.
Sorry I don't see an answer in this lab.
--Sebastien
Voyager
Voyager
Sorry, I think I led you down the wrong path.  You might be looking for UG1119, lab 1 then.
--Sebastien
