Observer rutabagazuma
design source remains after block diagram deletion
I have a block diagram from which I deleted a block 'SSDSP_SSDSPCh_wrapper_7_0'.   The block is gone from the diagram but remains in the sources viewer (see attachment).
Three other identical blocks were also deleted 'SSDSP_SSDSPCh_wrapper_(4,5,6)_0' without issue.
Vivado attempts to synthesize 'SSDSP_SSDSPCh_wrapper_7_0' when I synthesize the design.   The block fails synthesis.
How do I remove, completely, all references to this block?   There does not appear to be a way to do it from the sources viewer as 'remove file from project' is not an enabled option.
Re: design source remains after block diagram deletion
Hi @rutabagazuma
Did you try to do reset output products for the BD. It should clear everything
Florent
Resetting output products did not directly repair the problem.   At some point the tool dropped the references to the deleted IP.   I dont have an explanation as to what action brought vivado up to date though.
