disable VHDL 2008 in vivado 2018.2
   Is it possible to disable VHDL 2008 support in vivado 2018.2?
Nizar
Re: disable VHDL 2008 in vivado 2018.2
@nizar.bouzouita
If you do not want the file to be VHDL-2008. You can change the FILE_TYPE property to VHDL.
set_property file_type VHDL [get_files bft.vhdl]
--Syed
OK thanks but my question is more at projects level, I want to prohibit developers from using VHDL 2008.
I saw that there is the property "enable_vhdl_2008" for instance but I didn't find any documentation on it.
