document link
Provide document link where in which I can drag and pull the blocks and design as per my requirement. Is it possible to generate equivalent vhdl or verilog or c file of the block?
回复: document link
Are you talking about managing a block design using IPI? In that way,  you can take a look at the following doc:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug994-vivado-ip-subsystems.pdf
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug995-vivado-ip-subsystems-tutorial.pdf
You can create top-level HDL wrapper for the block design.
