equivalent verilog code to a schematic
I have created a ciruit for a simple cpu in xilinx and have used Ram16x4s as the memory and acc4 as the ALU/ACC. Have written a verilog code  and created an equivalent schematic for the control unit and connected these components to build a schematic for the cpu.
Can anyone please tell me how to find the equivalent verilog code for the whole circuit?
Thnaks.
Professor
Professor
Going from a schematic to structural Verilog is fairly simple
and straightforward.
1) Your top level module will have only the design's pins in the port list.
2) declare wires  for all of the interconnecting nets in your schematic.
3) Use instantiation for the blocks in the schematic.   For Verilog blocks
that you created you can get an instantiation template in the processes
for the source under "design utilities".  For library elements like the
RAM's you will find the correct Verilog instantiation templates in the
libraries guide.
Gabor
-- Gabor
Thanks so much, I'll try this.
sir plz plz plz give me your code for cpu ( even seperately of all modules)
I need it very very urgent plz sir ,I will be vry thankful to you sir..
My Id is "siddgupta1991@gmail.com"
There is Verilog code for an ALU here that you could perhaps steal.
Perhaps your supervisor(s) will not detect your laziness and plagiarism.
hello sir
i am students, i am have projects on "CPU" that make in vhdl/verilog code for fpga
so,  can  send me code for that.... i am also working on that it but i cant understand where to start,,.....
plz guide me
Instructor
Instructor
You might want to start here.
-- Bob Elkind
SIGNATURE:
Summary:
