Tom1
error 'Q' does not have attribute 'lenght'
I get "error 'Q' does not have attribute 'lenght'" in the line "Q <= std_logic_vector(to_unsigned(count, Q'lenght));"
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity ELE218_Counter_up is
GENERIC ( N:INTEGER :=8) ;
Port ( R : in STD_LOGIC_VECTOR (N-1 downto 0);
Resetn : in STD_LOGIC;
E : in STD_LOGIC;
L : in STD_LOGIC;
clk : in STD_LOGIC;
Q : out STD_LOGIC_VECTOR (N-1 downto 0));
end ELE218_Counter_up;
architecture Behavioral of ELE218_Counter_up is
signal count: Integer range 0 to 2**N ;
begin
PROCESS (Resetn, clk)
begin
if resetn = '0' then
count <= 0;
elsif clk'event and clk ='1' then
if L = '1' then
count <= to_integer(unsigned(R));
elsif E = '1' then
count <= count +1;
end if;
end if;
end PROCESS;
end Behavioral;
bruce_karaffa
Wouldn't it be just as easy to write:
Q <= std_logic_vector(to_unsigned(count, N));
bruce_karaffa
Or you could try spelling length correctly.
Tom1
haha, thank you. Even though english is not my native language I should spell that correctly
