dwisehart
get_msg_config -rules not always working in 2018.2
With a new project and no rules, the command does what I expect:
Message control rules currently in effect are:
Rule Name Rule Current Message Count
set_msg_config -id {Test-999} -new_severity INFO
11 set_msg_config -ruleid {11} -id {Test-999} -new_severity {INFO} 0
But after adding rules for a while, `set_msg_config -rules` no longer returns anything, not even the headers.  I am guessing it doesn't like one of the rules.  Is there a way to find out which one?  I have 83 rules at the moment.
syedz
@dwisehart
Can you try with -verbose switch? Also Can you share all the rules applied so that we can test this at our end?
You can find all the set_msg_config command applied in vivado.log file.
--Syed
dwisehart
Thanks for the reply, Syed.
Adding -verbose did nothing: `get_msg_config -verbose -rules` returns nothing.
The rules do show up in vivado.log
I have attached the log and journal file.
Daniell
PS.  This project has fewer rules, which I thought might help track it down.
