how i use DAC of spartan3e
please , i want the programs that operate DAC of sparatn3e and how to use these programs .thanks
noorqaqos,
Again, can you be more specific?
Which boards are you using? Which DAC is on the board? Do you need C/C++/... code to control the DAC or do you need to design logic to drive the DAC interface? ...
There have been a bunch of posts similar to this one, so maybe you can read those first.
Cheers,
Johan
Historian
Historian
A Spartan 3E FPGA does not have an on-board DAC.
Lie. It has DAC.
Historian
Historian
scrts wrote:
Lie. It has DAC.
No lie. Xilinx FPGA devices do not have onboard DACs.
You are confusing an eval board for the device. That's a newbie mistake.
Our friend said that he wants to "operate DAC Spartan  3E." And the Spartan-3E device has no such thing.
I work with virtex4, and maybe this is not aplicable to spartan 3e, but in the EDK there are two IP, delta sigma DAC and delta sigma ADC. Ok that there is no really dac on the device, but with only to discrete componentes ( R and C) outside the FPGA you can have a working DAC, and if you add a comparator, you can have an ADC.
Maybe he is speaking about this?
Historian
Historian
Nobody knows what's he's speaking about because he's as clear as mud.
