thilankathi
how to decide the number of jobs in Run settings in generate output products
I am using Vivado and have already validated the block design. I need to generate output products and i am not sure how to decide the number of jobs in run settings there. I have attached a screenshot of the window below.
Thanks in advanced
stephenm
@huizy If you are scripting, you can use something like:
proc numberOfCPUs {} {
    # Windows puts it in an environment variable
    global tcl_platform env
    if {$tcl_platform(platform) eq "windows"} {
        return $env(NUMBER_OF_PROCESSORS)
    # Check for sysctl (OSX, BSD)
    set sysctl [auto_execok "sysctl"]
    if {[llength $sysctl]} {
        if {![catch {exec {*}$sysctl -n "hw.ncpu"} cores]} {
            return $cores
    # Assume Linux, which has /proc/cpuinfo, but be careful
    if {![catch {open "/proc/cpuinfo"} f]} {
        set cores [regexp -all -line {^processor\s} [read $f]]
        close $f
        if {$cores > 0} {
            return $cores
    # No idea what the actual number of cores is; exhausted all our options
    # Fall back to returning 1; there must be at least that because we're running on it!
    return 1
Then use this like:
launch_runs synth_1 -jobs [numberOfCPUs]
watari
Professor
Professor
Hi @thilankathi
It depends on your computer.
How many cores and threads are there ?
gabed
Hi @thilankathi
If I don't need processing power for other applications, I typically maximize the number of jobs.
Cheers
nagender_patel
type set_param general.maxThreads 8 in tcl console
it depends on the number of cores your pc has...
hemangd
Hi @thilankathi
Go through this AR and UG 904 to understand more about the number of Jobs and its usage. https://www.xilinx.com/support/answers/60655.html
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug904-vivado-implementation.pdf
(page 7 onwards.)
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
thilankathi
Thanks for the replies guys. so does thid mean that the number of jobs means the number of jobs done in parallel? Is that why it depemds on the number of cores in your computer? Anyways how does it affect the performance on fpga? or it doesnt affect the performance inside fpga? I mean what depends on the number of jobs ?
Thanks in advance!
hemangd
@thilankathi
Check this at your end to understand it better. - Create a GUI project in Vivado - add multiple Xilinx IPs from IP catalog - now OOC pop up will come to generate its products where you will see that pop up asks to set the number of jobs - If you set 1 there then only one OOC synthesis will be done at a time. If you set more than 1 then you will see parallel OOC synthesis is happening for those IPs. You can see these in Design Runs tab.
Hope you will get your answers by doing this exercise.
hemangd
huizy
thanks!
stephenm
            return $cores
        close $f
        if {$cores > 0} {
            return $cores
    return 1
Then use this like:
