10-30-2020 06:45 PM - edited 10-30-2020 07:21 PM
I want to create a ip with axi_lite bus and ordinary ports , which item I should select between the "package a specified directory" and "create a new AXI4 peripheral"shown below in the figure ?
firstly I select the "package a specified directory" item,but I can not find the place which can select the axi bus type.
11-16-2020 01:55 PM
Hi @microchip_zhang
It looks like you may want to create a new AXI4 Peripheral if you want to select the axi bus type.
This document highlights the different options for creating/packaging IP.
UG 1118
Page 38: Packaging a Specified Directory
Page 40: Creating a New AXI4 Peripheral
11-16-2020 04:35 PM
Check this thread (and helpful findings from @dgisselq ) before you use the AXI-4lite interface Xilinx provides. I have found it to hang on writes.
It was relatively trivial to use other examples as the basis for memory mapped control of custom IP. I recently used analog devices system successfully.
Jerry
11-17-2020 02:20 AM
@olupj ,
I personally use this example slave any time I need an example AXI-lite slave IP to build from . 1) it's light on logic, 2) with the skid buffer's it's really high speed (faster than Xilinx's broken AXI-lite infrastructure), and 3) unlike Xilinx's demos it actually works.
Dan
11-17-2020 04:45 AM
Hey @dgisselq
I've the FMCOMMS a few times from Analog so I've stuck with their axilite slave.
Just trying to save @microchip_zhang a day of minor frustration with Xilinx's IP.
Jerry
11-23-2020 03:27 PM
thanks a lot for all of you
