how to edit bram controller+bram memory size?
Vivado 2015.1
In my block design am implementing the following structure (see figure)
When I try to edit the bram controller or the bram parameters (size, data width) all is greyed and it is not possible to change anything except the data width. Why?
Is there a way to setup the dimensions of my own memory block?
Re: how to edit bram controller+bram memory size?
Hello @davide.camerano,
If you check page #72 from below product guide, you will find that the values of these greyed out parameters are automatically propagated during the design validation from the master, when using IP Integrator.
http://www.xilinx.com/support/documentation/ip_documentation/axi_bram_ctrl/v4_0/pg078-axi-bram-ctrl.pdf
Ashish
You can edit depth in address editor
Thanks and Regards
Balkrishan
http://forums.xilinx.com/t5/Design-Tools-Others/Block-memory-generator-v8-2-Vivado-2014-1-stand-alone-mode-port/td-p/470142
Thanks and Regards
Balkrishan
Ashish
