ise IP in vivado?
i generate DCM and GTX in ISE 14.6,
can i reuse in the vivado, not  re-generate?
Re: ise IP in vivado?
Yes, you can add the .XCO file of ISE in Vivado. You should have the IP output files generated in ISE.
For more details refer to page-55 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug911-vivado-migration.pdf
These IP's clocking wizard and transciever wizard are present in Vivado too. Use IP's from Vivado IP catalog if possible.
Deepika.
Deepika.
Deepika.
Deepika.
yes you can use however i would recommend to generate again in Vivado
Thanks and Regards
Balkrishan
