wuxingkui
ise to vivado
I needed to open a ISE project in VIVADO, and there was an error at compile time,
[Synth 8-3493] module 'fpga_clk_gen' declared at 'G:/jun_fpga_test/TDC_MOTOR_FPGA/project_1/project_1.runs/synth_1/.Xil/Vivado-10332-Yct201907021144/realtime/FPGA_CLK_GEN_stub.vhdl:5' does not have matching formal port for component port 'clk_out2' ["G:/jun_fpga_test/TDC_MOTOR_FPGA/MotorController/CONTROLLER_TOP.vhd":100]
[Synth 8-285] failed synthesizing module 'MOTOR_CONTROLLER_TOP' ["G:/jun_fpga_test/TDC_MOTOR_FPGA/MotorController/CONTROLLER_TOP.vhd":43]
[Common 17-69] Command failed: Synthesis failed - please see the console or run log file for details
hemangd
Hi @wuxingkui
Share your test case with us for better understanding of it.
Which Vivado version are you migrating to?
hemangd
wuxingkui
vivado 2017.4
1.
FPGA_CLK_GENERATOR : FPGA_CLK_GEN
port map (CLK_IN1=>GCLK,
CLK_OUT1=>CLK_24MHZ,
CLK_OUT2=>CLK_1MHZ);
ERROR:
[Synth 8-3493] module 'fpga_clk_gen' declared at'G/FPGA_CLK_GEN_stub.vhdl:5' does not have matching formal port for component port 'clk_out2'
2.
architecture BEHAVIORAL of MOTOR_CONTROLLER_TOP is
signal CLK_24MHZ : std_logic;
signal CLK_1MHZ : std_logic;
signal locked_div : std_logic_vector (1 downto 0);
signal MOTOR_SPEED_VALUE : std_logic_vector (9 downto 0);
signal NET_SPEED_DETECT_DONE : std_logic;
signal SPI_TRIGGER : std_logic;
signal SSN_DUMMY : std_logic;
signal SPI_DIN : std_logic_vector (15 downto 0);
component FPGA_CLK_GEN
port ( CLK_IN1 : in std_logic;
CLK_OUT1 : out std_logic;
CLK_OUT2 : out std_logic);
end component;
ERROR:
I dont know what happened, this project works well in ISE, but in VIVADO, there are some errors.
hemangd
Hi @wuxingkui
Check FPGA_CLK_GEN_stub.vhd that clk_out2 input port is present or not. If not present, please define the clk_out2 port in the original file.
hemangd
