labs to add custom AXI slave and master modules in Vivado ?
Hi, dear elite,
 Occasionally, I saw the following lab slide. However, do you know where is the complete lab slides now ? I would like to refer for lab practice of Vivado. Thanks
https://forums.xilinx.com/xlnx/attachments/xlnx/GenDis/16930/1/adding%20ip.pdf
All the best,
Nan-Sheng
Scholar hbucher
Re: labs to add custom AXI slave and master modules in Vivado ?
@nanson You mean UG1118?
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug1118-vivado-creating-packaging-custom-ip.pdf
Scholar hbucher
@hbucher
Thanks. But what I would like to seek is the doc related to create a baseline arm-a9 embedded system in Vivado as reference doc for students.
I believe this is an old University program lab.
You may want to check with xup_zedboard@xilinx.com
The Zybo version of the lab is available at: http://xilinx.eetrend.com/files-eetrend-xilinx/forum/201703/11197-29177-course5-system-design-flow-on-zynq-zybo-lab.pdf
Fro zedboard tutorials and labs you might want to check the following
http://zedboard.org/support/design/1521/11
https://reference.digilentinc.com/learn/programmable-logic/tutorials/start
Additionally, I found the 2013.1 zedboad labs you asked about posted at: www.dc.uba.ar/materias/CoDisenio/2015/c2/descargas
Look under "Clase 14. 25 de noviembre de 2015"
The web page is in Spanish but the labs are in English
Scholar ronnywebers
@nanson, maybe the Xilinx University Program is interesting for you? I'm sure the lab slide comes from that place. You can check the workshops, but to have access to the solutions you'll need to register as a professor I think.
Also interesting are the Avnet / Silica tutorials : https://github.com/Architech-Silica
I think Xilinx should take an example of these Silica tutorials, and spend more time to write decent, in depth tutorials, it would prevent & solve a lot of questions on the forum.
Scholar ronnywebers
@howardp@nanson
you wrote 'this is an old University program lab'
I found a newer version (Vivado 2015x) on this page. The 'labdocs' under 2015x are common for Zybo and Zynq. The solutions are only accessible if you're registered as professor.
The latest XUP workshops are here
I wish that as a working developer (not student) I had access too to the presentations and solutions :-), these are great tutorials, I learned a lot from them.
