no ports update in .xml file after re-packaging custom IP
I tried to re-package custom IP (File -> IP -> Open IP-XACT File…). I expected that the component.xml file would have the updated port list, but it still has the old ports. Any suggestions?
I do not want to delete the IP from IP catalog and create another IP from scratch, as I need to replace the old IP symbol on BD with a new one nicely.
Thank you
Re: no ports update in .xml file after re-packaging custom IP
Did you refresh the IP catalog – after repackaging the IP?
It is possible that the component.xml was already updated, but you may be referencing the old pointer in the IP repo.
Also, is this a new issue with 2018.3 ?
Which Vivado release are you using?
Vivado v2018.3 (64-bit)
I did refresh the IP catalog after repackaging, but it is the first time (I am relatively a new Vivado user) the ports have been affected. Actually, the file component.xml has not been updated. I though it should, correct?
I am not aware of all issues with 2018.3, but I had troubles in a past to upgrade the IPs from 2017.2.
