Teacher muzaffer
packaging part of a block diagram
I have design based on the following XAPP: http://www.xilinx.com/support/documentation/application_notes/xapp1171-pcie-central-dma-subsystem.pdf
I would like to package the portion of the block diagram which is called "pcie cdma subsystem". This is a hierarchy of IP instantiated in the block diagram in addition to zynq_PS and some reset blocks. I would like to package just this cell. Is it possible to do this? Any suggestions are welcome.
Re: packaging part of a block diagram
Hi @muzaffer
I assume that pcie cdma subsystem is also a block design which is present inside the top level block design. If this is true then you can use write_bd_tcl command to export the TCL and use it to create block design in the project. Once this is done you can package the block design.
Deepika.
Teacher muzaffer
Actually both projects are created from bd.tcl files and I decided to copy parts of the bd.tcl to a file to source it in the target bd.tcl (or after sourcing the target bd.tcl). I am not following the suggested/usual methods to closely but it seems to work for me. These days I can even modify the bd.tcl manually to do design.
