boyerkg
pin group rtl block design
Hi All,
I have a RTL block in a general block design.  I want group pins into a bus, like is done automatically when I put together a AXI stream group.  The AXI stream group and associated clock automatically group together.
I have actually instantiated the DDR4 MIG in RTL and I have the c0_ddr4 pins listed.  I cannot figure out how to group them together to allow simple bus connection to the ddr4_sdram pin group in the block design.
Keith
florentw
Hi @boyerkg
You might want to have a look at the section Inferring Control Signals in a RTL Module in PG994 from p226. This should be what you are looking for.
PS: In vivado the name of the interface for DDR is VLNV xilinx.com:interface:ddrx_rtl:1.0
