Observer ali_gh70
problem with bus in ise
hello how should  i solve this problem ? i also used buffer but they didn't work .
Observer ali_gh70
Re: problem with bus in ise
the point is that u should change the name of bus .
for example if the bus name is (31:0) u should change it to prescaler(31:0).this name should be same with the name of input or output .
ise doesn't produce bus name either in schematic or in making instantiation templates
Hello @ali_gh70,
Which version of ISE are you using?
I recommend writing the RTL directly to avoid this issue.
Good Luck,
Chris
Observer ali_gh70
