processing system and OOC constraints
Hi all,
We have recently moved to partitioning our FPGA design into multiple Board Designs and then setting these board designs to be generated in OOC mode.  This was done to reduce the synthesis times for the overall design.  It works well but gives a critical warning w.r.t a board design which contains a Zynq processing system.  The problem seems to be related to the auto generate processing_system7 MIO constraints file and the setting of the package pin properties.   The board design is called PS.
All the critical warnings are generated during the implementation stage of the design. A typical message is shown below.
[Netlist 29-160] Cannot set property 'iostandard', because the property does not exist for objects of type 'pin'. ["/home/developer/LinOOC-N2/flightNESIE/flightNESIE.srcs/sources_1/bd/PS/ip/PS_processing_system7_0_0/PS_processing_system7_0_0.xdc":33]
The corresponding line in the Vivado OOC generated PS_processing_system7_0_0.xdc is
set_property iostandard "LVCMOS18" [get_ports "MIO[53]"]
These warnings only occur when the design is built in OOC mode.  The tool normally handles these MIO configuration type constraints as part of the processing_system7 IP configuration.
Are these warnings to be expected in the OOC flow as they are from a generated constraints file?  Are there any ways to alter the constraints files or IP generation for the processing system to prevent these warnings.
Walter
Walter
Re: processing system and OOC constraints
Update,
The issue was down to neglecting to connecting the FIXED_IO in the PS systems instantiation.
Walter
Update,
I think there maybe a naming issue w.r.t Vivado 2015.2 and the PS IP core when OOC is used.  The instantiation template for the PS system as generated by Vivado specifies the port FIXED_IO_mio [53:0].   However the OOC generated constraints refer to port  MIO[53:0] which is not a valid port name. I think  it should be referencing FIXED_IO_mio and not MIO hence the critical warning?
Walter
Update,
Walter
