Anonymous
Not applicable
project mode Vivado
i want to run a project without to copy all the files project.
how can i have a pointer to my rtl/xdc files?
thanks
Hello @Anonymous,
To remotely access the RTL/XDC without copying them in project directory, you need to uncheck the 'Copy sources into project' dialogue box while adding sources to project (As seen in below snapshot)
Capture.png).
Ashish
You can also use the command add_files to add the rtl/xdc files into the project without copying them into the local project directory.
unlike import_files, add_files does not copy source files into the local project folder.
to know more on how to use add_files, please refer page 56 of following UG
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug835-vivado-tcl-commands.pdf
Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
Refer below discussion:
http://forums.xilinx.com/t5/Design-Entry/Vivado-quot-Copy-Sources-Into-Project-quot-set-by-default-worst/td-p/506759
Anusheel
Helpful answer -> Give Kudos
Hello @Anonymous,
Did you check responses to your query? Are you still facing issue?
Ashish
Anonymous
Not applicable
yep its help me
thanks
Hello @Anonymous
Then Please close this thread. by marking the post as solution
--Syed
