Scholar muravin
question about disabling the IP cache
Hi All,
Is there a way to enable/disable IP cache per IP? It looks like IP cache setting is project-specific, not IP specific. I think we could benefit from an Enhancement Request for making this feature IP specific could be very useful given the fact that IP cache overwrites RTL changes.
BR
Vlad
Vladislav Muravin
Re: question about disabling the IP cache
There is TCL command for that. Check Pg 121 of UG835 - http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug835-vivado-tcl-commands.pdf
You can use -disable_cache switch to disable the cache for that IP.
Anirudh
Scholar muravin
Hi Anirudh,
I don't agree. There is no TCL command for that, sorry, the -disable_cache sets the project specific property IP_CACHE_PERMISSIONS.
If am wrong, could you please provide an example?
Thank you
Vlad
Vladislav Muravin
Scholar muravin
I think I found what I need as part of solving a bigger issue.
The way to delete an individual cache entry is to find it first and then manually remove it, i.e. say $ip is the name of the IP whose entry we'd like to remove from the cache repository (could be regexp-searched prior to that).
Again, there is NOTHING in Xilinx user guides that indicates that check_ip_cache can be used to do this on an IP basis. The following 2 command to the trick.
set cache_loc [lindex [split [check_ip_cache [get_ips $ip]] ":"] 2]
file delete -force [current_project]/[current_project].cache/ip/$cache_loc
Vladislav Muravin
